I have been trying to get JReceiver .2.3 working with RioPlay. This is my first foray into not using ARM. I am running Win2K Server over HPNA to my Rio. JRec is running and can play lists to Winamp. I have DHCP installed and serving an address to the Rio. But then nothing else. Te unit just says initializing, but the NFS log shows a bunch of entries like the following:
NFS read C:\Program Files\Rioboot\tftpboot\Default\sbin\init,4096 bytes 331776 offset
NFS read C:\Program Files\Rioboot\tftpboot\Default\sbin\init,4096 bytes 335872 offset
NFS read C:\Program Files\Rioboot\tftpboot\Default\sbin\init,4096 bytes 339968 offset
...these are the last three lines in the log.
Do you have some advice as to where I should go from here? Thanks. Scott.
